Cold boot FLEX200 SFP not coming online
USG FLEX 200 V5.37(ABUI.2)
So had a power cut that my UPS could not keep everything running then when power come back the SFP looked dead after checking which is connected to a NETGEAR GS110T things I did.
Reboot FLEX from UI no help
Reboot GS110T no help
Unplugged the power for FLEX and plugged back in SFP lights up and working
During the period of SFP not working, you can collect the console log when plugging into the SFP port, it would print out logs for our investigation.
However, you already recovered it by power cycling, we cannot check further. Anyway, you may collect them if anything happens.
Anyway, I suspect it's affected by static electricity, SFP is sensitive to static electricity. That's why you need a power cycling.0
Anyway, I suspect it's affected by static electricity, SFP is sensitive to static electricity. That's why you need a power cycling.0 -
Bonjour, je rencontre le même soucis, même après remplacement du module SFP.
Bonjour @Richard44160,
Pourriez-vous partager avec nous votre modèle de pare-feu, votre modèle SFP et le modèle de périphérique de connexion ?
Zyxel Melen0
- 603 USG FLEX H Series
- 481 News and Release
