Client VPN access to site A and B
Irvold
Irvold Posts: 3 image  Freshman Member
Hi
I am trying to create a senario link the one in the picture.
Now: VPN Client can connect to Site A and access local resources.
Site to Site VPN between Site A and Site B is working.
I want users on VPN Client to be able to acces both Site A and Site B, througth the Site to Site VPN.
How to do that?
  • Zyxel_Kay
    edited December 2024 Answer ✓
    Hi @Irvold
    To enable VPN clients connected to Site A to access resources at both Site A and Site B through the Site-to-Site VPN, you’ll need to configure policy routes on the firewalls at both Site A and Site B.
    For detailed guidance, please refer to the following threads, which discuss similar setups:
    Kay
  • Irvold
    Tanks, I have tried the steps in that thread, but without susses.
    My Policy Route on Site A
    Nyk_Net is the VPN Site-to-Site
    ORENYK_Net is Site B Net - 192.168.1.0/24
    RemoteAccess_Wiz_Client is the address pool for the VPN Clients: 10.0.1.1-10.0.1.254
    RemoteAccess_Wiz is the Client IPSec VPN
    MY Policy Route on Site B:
    ORENYK_Net is Site B Net: 192.168.1.0/24
    OREVOR_VPNKlient_pool is the VPN Client address pool: 10.0.1.1-10.0.1.254
    Vord_net is SITE-TO-SITE VPN
    ORENYK_net is Site B net: 192.168.0.0/24
    Site-to-Site VPN
    192.168.1.0/24 - 10.0.0.0/16
    Client VPN
    Local policy: 10.0.0.0/16
    Do I need to change LAN1 on site A? It's 10.0.0.0/24 as the rest of the net on Site A.
    Any suggestions for what I'm doing wrong?
  • Zyxel_Kay
    Hi @Irvold
    Could you please send us the startup-config.conf files for both of your devices via private message? This will help us review your setup more thoroughly.
    Kay
  • Zyxel_Kay
    Hi @Irvold
    As discussed in our private message, you can adjust your settings as follows to ensure your scenario works correctly:
    1. Site-to-Site VPN Configuration:
      1. Site A:
        • Local Policy: 10.0.0.0/8
        • Remote Policy: 192.168.1.0/24
      2. Site B:
        • Local Policy: 192.168.1.0/24
        • Remote Policy: 10.0.0.0/8
    2. Policy Route Adjustment:
      Remove or deactivate any policy routes configured on both sites.
    3. Remote Access VPN Adjustment:
      The remote access policy on Site A currently does not include the Site B subnet. Please adjust the Remote Access VPN settings on Site A as shown below:
      Untitled Image
    Without this configuration, the client won't know how to route traffic into the tunnel.
    Kay
  • Irvold
    Hi again.
    One side effect with this solution.
    The pc connected to Site A, now has access to Site B. BUT no internet access while the VPN Client is open.
    Can you help find a solution? For now I am changing back to sub /8.
    regards,
    Daniel
  • Zyxel_Kay
    Hi @Irvold
    As discussed on private msg., you may set the Site A policy rule as follows:
    • Rule1: source VPN client , dst: 192.168.1.0/24 next-hop: vpn tunnel
    • Rule2: source VPN client, dst: any , next-hop : wan with NAT.  policy-route.png
    Kay
  • HyungKim0105
    HyungKim0105 Posts: 10 image  Freshman Member
    Zyxel Certified Network Administrator - Security First Comment
    edited January 2025
    Hello Kay, I have the same issue and I checked all the configurations listed here but still cant get it to work.
    Would it be possible for me to send you the config files too?
