802.11r Not showing in Nebula Clients with WPA-3
I have zero clients showing with 802.11r capabilities…. This is with both NWA130be's and NWA50ax Pro. I tried toggling 802.11r to no avail….
Hi @jpblanch75 ,
Could you clarify where you're checking for 802.11r capabilities in zero clients? Are you looking at:
- The client list
- Wireless packet data
- Another location
Additionally, please let us know:
- Are you using your NWA130be's and NWA50ax Pro in Standalone or Nebula mode?
- What firmware version are you running on these devices?
Zyxel_Judy
I'm using Nebula, latest firmware and the client list.
What made me look was while walking between access points my phone would switch to cellular then back to Wi-Fi instead of I'm jumping APs. Using WPA2 it works fine and shows 802.11r in the client list.
Hi @jpblanch75 ,
What conditions are preventing you from seeing 802.11r capabilities in zero clients? Are you using any security methods other than WPA2?
Zyxel_Judy
I told you above in the first post and title combination. Am I not being clear? When using WPA3 security, none of my 802.11r capable devices show that capability in the client list.
Hi, I think I can confirm this problem too. There were zero statistics about clients unless I changed one device to a WPA2 SSID
It has been a few days, an update would be great!
Hi users,
Thank you for sharing the symptoms you observed.
After investigation, we confirm this is part of the current specifications - 802.11r is not available when using WPA3. We'll add this feature to our evaluation list for future consideration.
To keep users informed, we will add a note in the Nebula GUI soon to indicate that 802.11r is not available when using WPA3.Zyxel_Judy
- 213 Nebula Ideas
- 557 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
