WFH VPN impacted after updating 100H to 1.30(ABXF.1)
@Zyxel_Melen, is there a known reason why IPS would cause an issue with my outbound VPN connectivity from my Windows Laptop (using Global Protect)?
Also, is there a policy that can be excluded to alleviate the issue?
look at the IP exception
Hi @chrisfits7,
The VPN throughput will be affected, but it should not be like the speed you experienced. Could you provide the speed for disabling and enabling IPS to compare?
For security services, you can set IP exceptions to bypass. Just like @PeterUK shared.
Zyxel Melen0
- 602 USG FLEX H Series
- 480 News and Release
