WFH VPN impacted after updating 100H to 1.30(ABXF.1)
2»
  • chrisfits7
    chrisfits7 Posts: 8 image  Freshman Member
    @Zyxel_Melen, is there a known reason why IPS would cause an issue with my outbound VPN connectivity from my Windows Laptop (using Global Protect)?
    Also, is there a policy that can be excluded to alleviate the issue?
    PeterUK Posts: 4,416 image  Guru Member
    look at the IP exception
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @chrisfits7,
    The VPN throughput will be affected, but it should not be like the speed you experienced. Could you provide the speed for disabling and enabling IPS to compare?
    For security services, you can set IP exceptions to bypass. Just like @PeterUK shared.
    Zyxel Melen
