Router EX5601-T0 Media Server
Albesal
in Home Router
I connected an USB device on the USB port of the router: the file sharing works well but the Media Server doesn't work, it's not listed on the network.
I have a Media Server on the PC and it's visible and accessible from all devices connected to the router (LAN and WiFi).
Are there any setting that I have to do?
Firmware version is V5.70(ACDZ.2)C0
Thanks in advance, regards
Alberto
Hello @Albesal
Welcome to the forum.
Have you turned on Media Server, see section 5.4.2 of the user guide at
Kind regards,
Tony
Hi Tony,
thanks for your answer.
Yes, the media server on the router is ON.
The good news is that now it works: I don't know what happened, probably a setting in the Windows Network parameters.
Thanks and regards
Alberto
- 601 USG FLEX H Series
- 480 News and Release
