Do I need an ATA?
I have a Zyxel EX5601-T0 and need to connect a phone. Are the phone sockets suitable for a PSTN phone or do I need an Analog telephone Adapter?
Thanks in advance.
Chris
Hello @Chris_Grantham
Welcome to the forum.
Looking at https://www.zyxel.com/service-provider/global/en/products/ethernet-cpe/ethernet-iads/ex5601ex5600-t-series It seems like it has an ATA in built in.
andDepending on where you live and the plug on your PSTN phone, you might need a converter to an RJ11 plug.
For example, https://www.amazon.co.uk/Rhinocables%C2%AE-Socket-Telephone-Adaptor-White/dp/B00EVS5UZ2/ref=asc_df_B00EVS5UZ2?mcid=75a172d6a9eb378a9cd87c5f3e26a973&tag=googshopuk-21&linkCode=df0&hvadid=697342549349&hvpos=&hvnetw=g&hvrand=2125735404116547765&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045065&hvtargid=pla-564720359273&psc=1&gad_source=1 for the Rhino BT socket to RJ11 plug adapter.
Kind regards,
Tony
Kind regards,
Tony
Thanks Tony. That is a great help. And thanks for the link too.
Kind regards,
Chris
- 431 Beta Program
- 2.6K Nebula
- 169 Nebula Ideas
- 6K Security
- 375 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 266 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
