When using WPA3, Roaming is not working
jpblanch75
jpblanch75 Posts: 174  Master Member
First Comment Friend Collector Third Anniversary Community MVP
edited December 2024 in Nebula
From what I have been reading, because WPA3 uses Protected Management Frames, 802.11r has to be disabled. I also read that WPA3 is supposed to us PMKID for Roaming. This doesn't appear to be working as my device will always drop wifi between Access Points and not Roam.
  • jpblanch75
    Again:
    When using WPA3, Roaming is not working as it is supposed to using PMKID. I will drop wifi before grabbing a new Access Point.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @jpblanch75
    We tested roaming functionality using your Nebula site configuration with an SSID named "J4-5G" configured for WPA3-Personal security. Our testing confirmed successful client roaming between two access points as shown below.
    If your clients lose Wi-Fi connection before connecting to a new AP, please check your AP deployment to ensure proper signal coverage for client roaming.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
