FWA510 V1.18(ACGD.4)C0 - Icons' colors
GiuseppeR
GiuseppeR Posts: 369  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I have this indoor router that has icons on its top.
Now I have:
  • green power
  • green message
  • blu antenna bars
  • green world
  • green WPS
I have no internet connection available on the inserted SIM, so I expect to see RED or NOT VISIBLE "World icon".
I have disabled WPS, so I expect to see RED or NOT VISIBLE "WPS icon"
As it is right now, it seems that the 5G router is online. So I'm a little bit confused about its icons' colors.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,209  Zyxel Employee
    Hi @GiuseppeR,
    Based on the LED behavior:
    1. Do you connect an ethernet WAN?
    2. Do you enable Wi-Fi?
    Zyxel Melen
  • GiuseppeR
    edited December 2024
    Hello @Zyxel_Melen
    I see right now that WPS icon includes also WiFi, so it is green due to the fact I enabled a WiFi network for emergencies.
    Anyway the internet icon has a strange behaviour: the SIM inserted in the router is active, it has NO internet data plan available but the LED is still green. I expected to see it red.
    This is the network online graph for last 30 days:
    So that LED should be red.
  • Zyxel_Melen
    Hi @GiuseppeR,
    Thanks for sahring more details. Could you help to access FWA510 and screenshot the home page information so we can check this issue?
    Zyxel Melen
Nebula Tips & Tricks
