How to configure lan bridge on WAX620D-6E ?
gacquier
gacquier Posts: 4 image  Freshman Member
edited December 2024 in Nebula
On my site, I have a NWA50AX PRO as a root AP and a WAX620D-6E that I want to use as a repeater and a wireless bridge, linkedto an ethernet switch that accesses to a common printer.
WAX620D-6E works as a repeater, but the LAN port does not seems activated (no LED light from the LAN port nor from que switch port when I plug the RJ45 cable. If I use the Uplink port the LED lights up on both the AP and the switch, but I can't access the printer.
On Nebula the Wireless Bridge is notes as "enabled".
What have I missed ?
Thanks in advance for your suggestions !
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Hi @gacquier ,
    Please note that wireless bridging requires two compatible access points to function. The NWA50AX PRO does not have wireless bridge capability in its feature set.
    This means you'll need to consider alternative hardware options if wireless bridging is required for your setup. Please refer to Nebula Device function table to know the compatible AP
    Zyxel Nebula - Device function table
    Zyxel_Judy
    Untitled Image
  • Xydocq
    Xydocq Posts: 47 image  Freshman Member
    Did you check
    Site-wide > Configure > Access points > AP & port settings
    Under Port settings LAN1 has to be enabled too.
  • gacquier
    Thanks Xydoxq !
    Lan1 is enabled indeed, as well as lan2 and lan3. For each of them, PVID = 1 and Allowed VLANs = 1…
    Should I disable Lan 2 and 3 ?
    I managed to use an old (non zyxel) bridge for now while I try to get this WAX620D working…
    Thanks for your help :)
  • gacquier
    ok, I 'm afraid I found the problem. It seems that you need 2 hardware supporting wireless bridge, and in this case my configuration with NWA50AX PRO as root and WAX620D-6E as bridge will never work… Can you confirm ?
  • Xydocq
    hi @gacquier
    according to this
    Distinguishing between Smart Mesh and Wireless Bridge: Features and supported models — Zyxel Community
    both AP's have to support wireless bridge. I only have NWA130BE's installed.
  • Zyxel_Judy
    Hi @gacquier ,
    Zyxel_Judy
    Untitled Image
  • gacquier
    Thanks to both of you !
Nebula Tips & Tricks
