Routing policy redesign on Nebula with WANs connectivity check
GiuseppeR
in Nebula Ideas
Hello everyone,
as you know there is a limitation on design regarding policy route on Nebula platform. If you set a rule for routing there is no way to tell that rule to re-route traffic if the specified WAN goes down.
You can check that issue here:
I think it would be great to add this layer of usability, disabling the routing policy if the specified next-hop is down.
3
here the same problem: our customes have 2 oder more wan ports and the healthy check on nebuly DONT WORK :(
- 603 USG FLEX H Series
- 481 News and Release
