FLEX 100H Configuring VoIP/SIP related settings
hli
hli Posts: 2 image  Freshman Member
I'm sorry but we're not able find any VoIP/SIP related configuration settings in the Web admin interface. We're Looking for:
  • Enable/disable SIP ALG
  • Enable/disable SIP header transformations
  • Configuration of SIP Media Timeout / Signaling Timeout
  • Enable/disable Anomaly detection and prevention
  • Configuration of UDP Session Timeout
If there is no option in the UI, how the commands would be for CLI?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @hli ,
    Greeting Forum,
    We do not support SIP and sesson timeout functions currently.
    But there will be plans to support it in the future
    For ADP, We named "DoS Prevention" , There will be the same settings as ZLD ADP
    Thank you
  • Zyxel_Kevin
    Hi @hli ,
    Greeting Forum,
    Thank you
  • hli
    Hi Zyxel-Team
    Just wanted to ask if the mentioned features are available now in the current firmware version of the Flex H Series?
    And is there somewhere an updated list of the still missing features (in comparison to the normal Flex Firewalls)?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @hli
    SIP ALG function will be supported in the next firmware release which ETA is 2025 Q1.
    About the missing features, we currently do not have a list. Would you like to share what feature you are seeking?
    Zyxel Melen
