NWA130BE "Rate Limiting" not working permamentely ...
Hi @docducati
To better understand your situation, could you please share more details with us?
- What is the current firmware version of your NWA130BE? We recommend keeping your device firmware up to date for optimal performance.
- You mentioned that the rate limiting is sometimes working, but mostly not. Could you please share the symptoms you've observed? A screenshot of a speed test or any other relevant information would be helpful. Also, please let us know the time period when you experienced this issue.
- Is the rate limiting issue affecting all connected devices, or only specific stations? If it’s affecting specific devices, could you please share the client MAC address with us via private message?
- Please collect the diagnostic file from your AP when the issue occurs and share it with us via private message. Additionally, please let us know the exact time when the issue happens.
Once we have this information, we’ll be able to assist you further.
Kay
Hi Zyxel_Kai
- current installed Firmware: Firmware Version:V7.00(3) / 2024-10-16 12:40:50
- Symptons are, mobile decive connect tp the specific SSID and test via APP "Speedtest.net" link in the config example: https://community.zyxel.com/en/discussion/3157/how-to-set-up-rate-limiting-for-bandwidth-control
- I've tested the behaivior with iPhone 7 & Samsung Galaxy S22+
- Where can I collect this debug log?
0 - What is the current firmware version of your NWA130BE? We recommend keeping your device firmware up to date for optimal performance.
Hi @docducati
You can refer to this guidance article for instructions on collecting the AP diagnostic file:
Once you've collected the file, please share it with us via private message.
Besides, could you please share with us the screenshot of your speedtest result too?
Kay
Hi Zyxel_Kai,
ok, thank you. I will do it tomorrow.
Hi Zyxel_Kai
I sent you a message.
Hans
I noticed that rate limiting applies after the client disconnects and reconnects to the SSID.
So after you enable rate limiting, all stations must reconnect, otherwise it doesn't apply to them.0 -
After testing this feature for some time, i can say that this feature does not work.
NWA130BE does not rate limit stations according to the Rate Limiting settings.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
