[USG LITE 60AX] NAT rules limit is 10?
Hi there,
I am using USG LITE 60AX as my security router for home. There’s a Synology NAS behind USG LITE 60AX. I am trying to set NAT rules to have most of services provided by NAS able to be accessed from internet. However, the limit of NAT rules becomes the showstopper and I have no idea how can I do.
Can you provide your suggestions?
Hi @antohsu
Sorry for the delayed reply. After checking with our product team, we will enlarge the maximum number of the NAT rule to support your scenario.
Here's the idea post and we will monitor the comments and votes to evaluate.
Zyxel Melen0
Hi @antohsu
Could you share the ports you are going to set up? This will help us to find a solution for you.
Zyxel Melen0 -
Hi Melen,
I'm trying to configure the MailPlus Server which is using TCP for below ports:
1344、4190、5000 (HTTP)、5001 (HTTPS)、5252、8500 - 8520、8893、9526 - 9529、10025、10465、10587、11211、11332 - 11334、12340、24245、24246
Synology link for your reference:
Thanks.
Hi @antohsu
Zyxel Melen0
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
