limit bandwidth Access points
i got something what's not very logic in my opinion.
when you set bandwidth limitation for example on 1 mb you got this
when you put it on unlimited you got this:
I should expect the bullit by unlimited on the right side, en the row would be green instead of white…
don't know if this is the right place to ask for a change….
(offcourse i see unlimited, but can be made a little more clear.)
yours dennis
Hi @Dpj
Thanks for your input. I have help to let our product team know this suggestion and help creating an idea post. We will discussion this suggestion and also monitor the idea post to evaluate it.
Zyxel Melen0
Hi @Dpj
Zyxel Melen0
- 603 USG FLEX H Series
- 481 News and Release
