SCR50AXE wrong color code for ports on Nebula
GiuseppeR
GiuseppeR Posts: 658 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I was looking at port speed on Nebula for the security router 50AXE and you are NOT able to understand which port has slower speed:
As you can see my port4 is working at 100 Mbps but it is green like a standard 1 Gbps port.
Considering the latest color coding of Zyxel, that port4 should be orange, following this scheme:
Nebula Tips & Tricks
