Help Needed to Configure Zyxel EMG1702-T10A as a Repeater
Hello everyone,
I'm trying to configure my Zyxel EMG1702-T10A router to work as a repeater, but I'm having trouble finding the correct settings. I've accessed the router's web interface but couldn't locate the options for repeater mode. Here are the options available: DHCP Mode, Start IP Address, End IP Address, Max lease time, Domain Name, DNS Relay, Primary DNS, Secondary DNS, DNS, QoS, UPnP, Routing, DDNS, MLD, ALG, IP Tunnel, ACL, IPv4 Filter, IPv6 Filter, URL Filter, MAC Filter, DMZ, DoS, Virtual Server, Port Triggering, Igmp Proxy.
Could anyone guide me on how to enable and configure the repeater mode on this router?
Thank you in advance for your help!
Hello @benaiastorres
Welcome to the forum.
I have not been able to find much information about your Router, except https://loja.dca.com.br/roteador-dual-band-ac750-4p-10100---24-ghz--50-ghz-ac-c-tr069--preset---emg1702-t10a---zyxel---96970500#ECOM_PAGINA_PRODUTO_TAGS
I think that if you are looking for your EMG1702-T10A to be a Wifi Repeater, then I do not think that EMG1702-T10A will do it.
Maybe a WiFi extender from Zyxel or TP-Link or Netgear would help you?
- see https://www.zyxel.com/service-provider/emea/en/products/network-extenders or https://www.tp-link.com/uk/home-networking/range-extender/ and https://www.netgear.com/uk/home/wifi/range-extenders/ for examples.Merry Christmas 2024 and Kind regards,
Tony1
Tony1
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
