Missing configuration functions
Missing configuration functions: I wanted to dig myself more deeper into the options the GS1920-24 offers. How can I jump into these options after logging in into the configuration webserver (192.168. .. . xy)?
I don't want to use this Nebula stuff but it seems to be dependent from this Cloud?
Status says:
Hybrid Mode
Cloud
Cloud Connection Status
Connected
How can I un-connect it and do all configurations locally?
Hi @projmgmtde
From your description, it seems your GS1920-24 switch is currently registered to the Nebula Control Center(Nebula CC). When a device is managed via Nebula CC, certain local configuration options become limited. If you prefer to manage your device locally, you can follow the steps in the guide below to unregister your switch from Nebula CC:
After unregistering, Nebula CC will push a factory reset command to the switch, and it will reboot into standalone mode.
Additionally, once in standalone mode, you can disable Nebula Control Center Discovery by navigating to SYSTEM > Cloud Management on the switch's web interface. This will prevent the switch from reconnecting to Nebula CC automatically.
Kay
Hi @projmgmtde
Kay
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
