Assigning static IP to clients with Static DHCP (EX3600-T0)
Hello!
I'm trying to assign static IP address (static DHCP) to a client in my house, but I can't find a setting in my router to do so.
When I read the manual (https://download.zyxel.com/EX3301-T0/user_guide/EX3301-T0_V5.15_5.70_Ed2.pdf), it should be under Network Settings → Home Networking → Static DHCP. But I don't have the "Home Networking" category under Network Settings (see picture).
Is the router in some kind of "Simple mode"? Or does my router lack the ability to set static DHCP?
Thank you!
First you have to login as admin not as a user .
But i think you have a special "branded" firmware from your ISP and so you have not all options . It is better for the ISP for always correct configuration . If the Router is in property of your ISP you dont have the right to force the Installation of the regular firmware .
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
