USG FLEX 200H -1.30 (ABWV.1) - Port 3 is down
HUBERT_KASPRZAK
HUBERT_KASPRZAK Posts: 18 image  Freshman Member
edited December 2024 in USG FLEX H Series
  • For two days at a similar time, Port 3 has been turned off. The only solution is to remove the cable and turn it on again. This is not a cable problem.
2024-12-30 07:34
system
Port 3 is down!
0.0.0.0
0.0.0.0
2024-12-31 07:38
system
Port 3 is down!
0.0.0.0
0.0.0.0
    Can you add another port then use that to see if the same thing happens with that port?
  • HUBERT_KASPRZAK
    • I will check in the next few days and let you know
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @HUBERT_KASPRZAK,
    Could you also share which connecting device encountered this issue?
    Zyxel Melen
  • HUBERT_KASPRZAK
    Further diagnosis of the problem on January 1-2, 2025. The system turns Port 3 off and on by itself.
    2025-01-01 19:53
    alert
    system
    Port 3 is down!
    2025-01-02 06:34
    alert
    system
    Port 3 is up!
    2025-01-02 06:34
    alert
    system
    Port 3 is down!
    2025-01-02 06:39
    alert
    system
    Port 3 is up!
    2025-01-02 06:39
    alert
    system
    Port 3 is down!
    2025-01-02 06:40
    alert
    system
    Port 3 is up!
    2025-01-02 06:40
    alert
    system
    Port 3 is down!
    2025-01-02 06:41
    alert
    system
    Port 3 is up!
    2025-01-02 06:41
    alert
    system
    Port 3 is down!
    2025-01-02 06:41
    alert
    system
    Port 3 is up!
    2025-01-02 06:41
    alert
    system
    Port 3 is down!
    2025-01-02 06:42
    alert
    system
    Port 3 is up!
    2025-01-02 06:42
    alert
    system
    Port 3 is down!
    2025-01-02 06:42
    alert
    system
    Port 3 is up!
    2025-01-02 06:42
    alert
    system
    Port 3 is down!
    2025-01-02 06:43
    alert
    system
    Port 3 is up!
    2025-01-02 06:43
    alert
    system
    Port 3 is down!
    2025-01-02 06:43
    alert
    system
    Port 3 is up!
    2025-01-02 06:43
    alert
    system
    Port 3 is down!
    2025-01-02 06:47
    alert
    system
    Port 3 is up!
    2025-01-02 06:47
    alert
    system
    Port 3 is down!
    2025-01-02 06:47
    alert
    system
    Port 3 is up!
  • Zyxel_Melen
    If you still encounter this issue after some cross-tests, please help collect the diagnostic and share the connecting device that has this issue.
    USG FLEX H Series - Download Diagnostic Files from GUI — Zyxel Community
    Zyxel Melen
