VMG3625-T20A Cant Turn Off WiFi Password
[Deleted User]
in Home Router
Hi there,
I have a Zyxel VMG3625-T20A (V5.30(ABIE.6)).
For some reason I'm not able to turn off WiFi security to run open WiFi (I intend to use MAC address filtering for whitelisting).
Hi @CntrlAltDel
Welcome to the forum.
The user guide available at https://www.zyxel.com/global/en/support/download might help you.
- enter VMG3625 in the search box.
Is it possible to set encryption or WiFi security to none?
I think that it is if you use chose No Security as the Security Level , see below screenshot, but at your risk.
If you select WPA2-PSK I e. Pre-shared key, then the firmware will probably require the entry of a password.
Happy new year and kind regards Tony.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
