USG FLEX 200H -1.30 (ABWV.1) - Port 3 is down
- For two days at a similar time, Port 3 has been turned off. The only solution is to remove the cable and turn it on again. This is not a cable problem.
2024-12-30 07:34 | system | Port 3 is down! | 0.0.0.0 | 0.0.0.0 |
2024-12-31 07:38 | system | Port 3 is down! | 0.0.0.0 | 0.0.0.0 |
Can you add another port then use that to see if the same thing happens with that port?
- I will check in the next few days and let you know
Hi @HUBERT_KASPRZAK,
Could you also share which connecting device encountered this issue?
Zyxel Melen0 -
Further diagnosis of the problem on January 1-2, 2025. The system turns Port 3 off and on by itself.
2025-01-01 19:53
alert
system
Port 3 is down!
2025-01-02 06:34
alert
system
Port 3 is up!
2025-01-02 06:34
alert
system
Port 3 is down!
2025-01-02 06:39
alert
system
Port 3 is up!
2025-01-02 06:39
alert
system
Port 3 is down!
2025-01-02 06:40
alert
system
Port 3 is up!
2025-01-02 06:40
alert
system
Port 3 is down!
2025-01-02 06:41
alert
system
Port 3 is up!
2025-01-02 06:41
alert
system
Port 3 is down!
2025-01-02 06:41
alert
system
Port 3 is up!
2025-01-02 06:41
alert
system
Port 3 is down!
2025-01-02 06:42
alert
system
Port 3 is up!
2025-01-02 06:42
alert
system
Port 3 is down!
2025-01-02 06:42
alert
system
Port 3 is up!
2025-01-02 06:42
alert
system
Port 3 is down!
2025-01-02 06:43
alert
system
Port 3 is up!
2025-01-02 06:43
alert
system
Port 3 is down!
2025-01-02 06:43
alert
system
Port 3 is up!
2025-01-02 06:43
alert
system
Port 3 is down!
2025-01-02 06:47
alert
system
Port 3 is up!
2025-01-02 06:47
alert
system
Port 3 is down!
2025-01-02 06:47
alert
system
Port 3 is up!
If you still encounter this issue after some cross-tests, please help collect the diagnostic and share the connecting device that has this issue.
USG FLEX H Series - Download Diagnostic Files from GUI — Zyxel Community
Zyxel Melen0
- 441 Beta Program
- 292 Service & License
