Detecting a vpn anonymizer in the local network and who is using it?
mike4682
mike4682 Posts: 5 image  Freshman Member
I have an ATP500 firewall. There has been someone inside the network using express vpn before connecting to the internet. I can see in the App Patrol that it is being used, but I'd like to see if its an employee on the company network or a contractor using our guest wifi. Is there a way to log the ip and mac of the machine using the vpn anonymizer? I've tried activating the logs and using it from my machine, but I can't seem to find where in the logs it exists if it does exist. Thanks in advance for any help or ideas on the subject!!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @mike4682,
    Did you configure App Patrol to block the VPN software? If yes, the event log should record the client IP address that triggered App Patrol blocking.
    Zyxel Melen
  • Zyxel_Melen
    Hi @mike4682,
    Zyxel Melen
