Client VPN access to site A and B
Hi
I am trying to create a senario link the one in the picture.
Now: VPN Client can connect to Site A and access local resources.
Site to Site VPN between Site A and Site B is working.
I want users on VPN Client to be able to acces both Site A and Site B, througth the Site to Site VPN.
How to do that?
Hi @Irvold
To enable VPN clients connected to Site A to access resources at both Site A and Site B through the Site-to-Site VPN, you’ll need to configure policy routes on the firewalls at both Site A and Site B.
For detailed guidance, please refer to the following threads, which discuss similar setups:
Kay
Tanks, I have tried the steps in that thread, but without susses.
My Policy Route on Site A
Nyk_Net is the VPN Site-to-Site
ORENYK_Net is Site B Net - 192.168.1.0/24
RemoteAccess_Wiz_Client is the address pool for the VPN Clients: 10.0.1.1-10.0.1.254
RemoteAccess_Wiz is the Client IPSec VPNMY Policy Route on Site B:
ORENYK_Net is Site B Net: 192.168.1.0/24
OREVOR_VPNKlient_pool is the VPN Client address pool: 10.0.1.1-10.0.1.254
Vord_net is SITE-TO-SITE VPN
ORENYK_net is Site B net: 192.168.0.0/24Site-to-Site VPN
192.168.1.0/24 - 10.0.0.0/16
Client VPN
Local policy: 10.0.0.0/16
Do I need to change LAN1 on site A? It's 10.0.0.0/24 as the rest of the net on Site A.
Any suggestions for what I'm doing wrong?
Hi @Irvold
As discussed in our private message, you can adjust your settings as follows to ensure your scenario works correctly:
- Site-to-Site VPN Configuration:
- Site A:
- Local Policy:
10.0.0.0/8
- Remote Policy:
192.168.1.0/24
- Local Policy:
- Site B:
- Local Policy:
192.168.1.0/24
- Remote Policy:
10.0.0.0/8
- Local Policy:
- Site A:
- Policy Route Adjustment:
Remove or deactivate any policy routes configured on both sites. - Remote Access VPN Adjustment:
The remote access policy on Site A currently does not include the Site B subnet. Please adjust the Remote Access VPN settings on Site A as shown below:
Without this configuration, the client won't know how to route traffic into the tunnel.Kay
0 - Site-to-Site VPN Configuration:
Hi again.
One side effect with this solution.
The pc connected to Site A, now has access to Site B. BUT no internet access while the VPN Client is open.
Can you help find a solution? For now I am changing back to sub /8.
regards,
Daniel
Hello Kay, I have the same issue and I checked all the configurations listed here but still cant get it to work.
Would it be possible for me to send you the config files too?
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
