VPN with 2FA don't work
Gaetano
Gaetano Posts: 20 image  Freshman Member
Once the VPN is set up, the screen asking for the verification code does not appear. How can I make the screen appear? I have already tried with different types of VPN and enabled the port. Can anyone suggest a solution? Thanks
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    You can create, on desktop, a link to http(s)://LANIP:PORT
  • Zyxel_Kay
    Hi @Gaetano
    Could you please share with us the firewall model and the type of VPN you’re using?
    If you’re using a USG FLEX/ATP firewall with the Zyxel VPN Client to establish a VPN tunnel, the authentication page should automatically pop up in your browser. However, for SSL VPN or L2TP VPN, the authentication screen does not appear automatically, and you’ll need to manually enter the correct URL in your browser.
    For more detailed guidance, please refer to this article:
    Additionally, as @valerio_vanni suggested, you can create a shortcut on your desktop or bookmark the URL for easier access.
    Kay
  • Gaetano
    So do I have to start the link created on the desktop and then start the vpn or the other way around?I have a usg flex 200 and I use the windows client for vpn.
  • Zyxel_Kay
    Hi @Gaetano
    If you want the authentication page to pop up automatically in your browser, the recommended approach is to use the Zyxel VPN Client (SecuExtender) to establish the VPN connection.
    However, if you're using a different VPN method, you'll need to manually enter the correct URL in your browser to input the verification code. As previously mentioned, creating a desktop shortcut or bookmarking the URL can make this process more convenient.
    Kay
  • Gaetano
    I have done some tests with secuExtender and the pop-up does not appear, I am using version 4.0.4.0
  • valerio_vanni
    What type of vpn?
    SSL, L2TP, Ipsec
    Only the latest can have automatic popup
  • Gaetano
    SSL o IKEv2,
    thanks for the reply.
    I'll do some tests right away to prove it
  • valerio_vanni
    edited January 8
    With IKEv2 it should work.
    You have to set http://LanIP:PORT in phase2 settings (script "When this tunnel is opened").
