Why not possible customize the Nebula gui tailoring to the managed devices?
Hi @Feco ,
The Nebula menu is designed to show features specifically supported by each device type. For instance, the screenshot shows features available for Security routers (SCR50AXE and USG Lite 60AX).
Regarding the Static Route feature under Security Router > Interface - we confirm that SCR50AXE does support this. Could you describe the specific issue you're experiencing with this feature?
Zyxel_Judy
Hi @Feco ,
Zyxel_Judy
Hi Judy, thanks for your helping hand!
I set the following interfaces:
1: "Name"= "LAN" ; "IP address"="192.168.168.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"=""; "Guest"="OFF" (note: this is an ethernet interface)
2: "Name"= "LAN2" ; "IP address"="192.168.2.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"="2"; "Guest"="OFF" (note: this is a wifi subnet)
3: "Name"= "LAN3" ; "IP address"="192.168.3.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"="3"; "Guest"="OFF" (note: this is a wifi subnet)
I set the following SSIDs (I think the relevant info only the VLAN ID)
1: "Name"="WIFI_2"; "VLAN ID"="2"; "Guest Network"="OFF"
2: "Name"="WIFI_3"; "VLAN ID"="3"; "Guest Network"="OFF"
I would like to reach an IP located in "LAN" from "LAN3".
Is this possible? Thank you!
Hi @Feco ,
Yes, in your network configuration, devices in LAN3 can communicate with devices in the LAN subnet.
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
