VPN with 2FA don't work
You can create, on desktop, a link to http(s)://LANIP:PORT
Hi @Gaetano
Could you please share with us the firewall model and the type of VPN you’re using?
If you’re using a USG FLEX/ATP firewall with the Zyxel VPN Client to establish a VPN tunnel, the authentication page should automatically pop up in your browser. However, for SSL VPN or L2TP VPN, the authentication screen does not appear automatically, and you’ll need to manually enter the correct URL in your browser.
For more detailed guidance, please refer to this article:
Additionally, as @valerio_vanni suggested, you can create a shortcut on your desktop or bookmark the URL for easier access.
Kay
See how you've made an impact in Zyxel Community this year!
So do I have to start the link created on the desktop and then start the vpn or the other way around?I have a usg flex 200 and I use the windows client for vpn.
Hi @Gaetano
If you want the authentication page to pop up automatically in your browser, the recommended approach is to use the Zyxel VPN Client (SecuExtender) to establish the VPN connection.
However, if you're using a different VPN method, you'll need to manually enter the correct URL in your browser to input the verification code. As previously mentioned, creating a desktop shortcut or bookmarking the URL can make this process more convenient.
Kay
I have done some tests with secuExtender and the pop-up does not appear, I am using version 4.0.4.0
What type of vpn?
SSL, L2TP, Ipsec
Only the latest can have automatic popup
SSL o IKEv2,
thanks for the reply.
I'll do some tests right away to prove it
With IKEv2 it should work.
You have to set http://LanIP:PORT in phase2 settings (script "When this tunnel is opened").
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 272 USG FLEX H Series
- 274 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 392 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 74 Security Highlight
