API connection
I have read information about connecting to nebula with an api. we would like to retrieve at first some basic information, like offline\online status of usg flex, switches and accesspoints, and also retrieve logging messages.
Is it correct that we need an api key from you? because for now, i just get the message unautorized.
Hi @Dpj,
You can get your API key by yourself. Please navigate to My devices & services > NCC OpenAPI Key to generate.
Zyxel Melen0
Hi @Dpj,
Zyxel Melen0 -
Thx. I had read an old post. In that time you couldn't create an API key on your own.
but clear.
by the way, i saw an mistake in the online manual. (at least a assume)
DNS Content Filter
Select whether to enable DNS content filter, in addition to web content filtering.The DNS Content Filter allows the Nebula Device to block access to specific websites by inspecting DNS queries made by users on your network. Content Filter checks all DNS queries including DNS queries to remove DNS servers.
at the end, there is writen "to remove DNS servers", but i assume it should be "remote servers" isn't it?
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
