Why not possible customize the Nebula gui tailoring to the managed devices?
Hi @Feco ,
The Nebula menu is designed to show features specifically supported by each device type. For instance, the screenshot shows features available for Security routers (SCR50AXE and USG Lite 60AX).
Regarding the Static Route feature under Security Router > Interface - we confirm that SCR50AXE does support this. Could you describe the specific issue you're experiencing with this feature?
Hi @Feco ,
Hi Judy, thanks for your helping hand!
I set the following interfaces:
1: "Name"= "LAN" ; "IP address"="192.168.168.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"=""; "Guest"="OFF" (note: this is an ethernet interface)
2: "Name"= "LAN2" ; "IP address"="192.168.2.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"="2"; "Guest"="OFF" (note: this is a wifi subnet)
3: "Name"= "LAN3" ; "IP address"="192.168.3.1"; "Subnet mask"="255.255.255.0"; "VLAN ID"="3"; "Guest"="OFF" (note: this is a wifi subnet)
I set the following SSIDs (I think the relevant info only the VLAN ID)
1: "Name"="WIFI_2"; "VLAN ID"="2"; "Guest Network"="OFF"
2: "Name"="WIFI_3"; "VLAN ID"="3"; "Guest Network"="OFF"
I would like to reach an IP located in "LAN" from "LAN3".
Is this possible? Thank you!
Hi @Feco ,
Yes, in your network configuration, devices in LAN3 can communicate with devices in the LAN subnet.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
