API connection
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I have read information about connecting to nebula with an api. we would like to retrieve at first some basic information, like offline\online status of usg flex, switches and accesspoints, and also retrieve logging messages.
Is it correct that we need an api key from you? because for now, i just get the message unautorized.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Dpj,
    You can get your API key by yourself. Please navigate to My devices & services > NCC OpenAPI Key to generate.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Dpj,
    Zyxel Melen
  • Dpj
    Thx. I had read an old post. In that time you couldn't create an API key on your own.
    but clear.
    by the way, i saw an mistake in the online manual. (at least a assume)
    DNS Content Filter
    Select whether to enable DNS content filter, in addition to web content filtering.The DNS Content Filter allows the Nebula Device to block access to specific websites by inspecting DNS queries made by users on your network. Content Filter checks all DNS queries including DNS queries to remove DNS servers.
    at the end, there is writen "to remove DNS servers", but i assume it should be "remote servers" isn't it?
  • Zyxel_Melen
    Hi @Dpj,
    Thanks for pointing it out. We will correct our online document.
    Zyxel Melen
Nebula Tips & Tricks
