[NEBULA] VPN with Ubuntu 18.04
Goodmorning everyone,
With an NSG50 gateway I created a vpn l2tp ipsec. With windows working properly.
I'm trying to configure a linux client with ubuntu 18.04 but it doesn't connect.
I added l2tp support on ubuntu following this guide:
but still does not connect.
Are there any other parameters to add? I was thinking about the phase 1 and 2 algorithms but I can't find any settings on nebula to know how they are set.
Has anyone already addressed this problem?
Thank you!
I can establish the tunnel successfully with Ubuntu is your NSG located behind the NAT gateway?
And is there any relevant clues in event log?0 -
no particular event in the event log. the NSG (nebula) is placed behind a router with the nat activated (NOT double nat). VPN with a windows client works correctly.
@MGK , I just follow the steps from the link you provide and I can establish L2TP VPN between my Ubuntu(18.0.4) and my NSG100.
I just use like what the website says:
Phase 1 Algorithms: 3des-sha1-modp1024
Phase 2 Algorithms: 3des-sha1
If you use different, maybe you may share what algorithms you use.
now works,it wasn't the phase one and two algorithms I had put in, but I had to deselect the use of PAP from the PPP settings.Thanks a lot!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
