Nebula app
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
We are missing an option in the Nebula app. Through the portal there is an option to configure port profiles. This option is missing in the app. I hope this can be added.
Yours dennis
3 votes
Active · Last Updated
  • Zyxel_Kay
    edited January 2025
    Hi @Dpj
    Currently, the Nebula Mobile app is designed to provide essential configuration options. For advanced settings, accessing the Nebula Control Center (web portal) is necessary.
    Could you clarify which specific port profile configurations you're referring to? Are they related to switch ports or something else? At present, the mobile app allows you to configure switch port settings, including PoE, LLDP, speed, and VLAN.
    Kay
  • Dpj
    Hello Kay,
    We just created a few port profiles, with specific settings, like PVID, POE on or of, trunk or access. I saw i can change those settings like you mentioned above. (which does the same off course), but i would expect that you also can choose an port profile in the nebula app.
    When i allready can change the PVID etc i don't think choosing an port profile would be an "advanced setting".
  • Zyxel_Kay
    Hi @Dpj
    We'll be monitoring the votes and comments as part of our evaluation process.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Kay
  • CoreSys
    CoreSys Posts: 1 image  Freshman Member
    Agree with DPJ, the ability to view/change port profile through the app would be extremely helpful
Nebula Tips & Tricks
