Install firmware update on standby slot
From what I can tell Nebula seems to install firmware on the running slot which is bad idea and would think it be better to install on standby slot.
I would normally update the firewall by local UI for the standby slot but there are times if you have fix releases that stop you when a new release comes out which is silly and can only use Nebula to update the firmware.
Hi @PeterUK ,
Please provide the model's name and firmware version of your device so we can better assist you.
Zyxel_Judy
Hi Judy
As in I have FLEX200H with
slot 1 running V1.30(ABWV.1)ITS-24WK47-m6271
slot 2 Standby V1.21(ABWV.0)ITS-24WK43-1022-241001089
Should I only be able to update by Nebula I would like it to update to standby and not running this way firmware slots don't get old
Hi @PeterUK ,
Thank you for bringing this to our attention.
We have confirmed this current behavior and plan to enable the Nebula firmware to update using the standby partition in an upcoming firmware update.
Please stay tuned to our Security News & Release announcements for information about this enhancement.Zyxel_Judy
Just updated firmware today V1.31 and it still only used running slot the standby slot still old
Hi @PeterUK ,
Version 1.31 does not include the solution you requested. According to our schedule, this feature will be merged into Version 1.32, which is planned for release at the end of February.
Zyxel_Judy
Ok thanks was just checking
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
