Zyxel XS3700-24 How to erase the configuration and reset password.
paulluo0510
paulluo0510 Posts: 1 image  Freshman Member
I have a Zyxel XS3700-24 switch. When I enter Debug Mode and use the altc command to perform a CRC and restore the settings, I encounter an error message. However, I couldn't find the firmware or bin/rom files on Zyxel's official website.
May I ask if there is a solution to this issue?
Thank you.
isgoodpaul@gmail.com
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @paulluo0510 ,
    I will send the bin/rom files to you via private message. Please check your community message box.
    Please be aware that the XS3700-24 model has reached its EOL status. For optimal performance and support, we recommend exploring our current switch offerings here:
    Switch | Zyxel Networks
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @paulluo0510 ,
    Zyxel_Judy
    Untitled Image
