Nebula app
We are missing an option in the Nebula app. Through the portal there is an option to configure port profiles. This option is missing in the app. I hope this can be added.
Yours dennis
Hi @Dpj
Currently, the Nebula Mobile app is designed to provide essential configuration options. For advanced settings, accessing the Nebula Control Center (web portal) is necessary.
Could you clarify which specific port profile configurations you're referring to? Are they related to switch ports or something else? At present, the mobile app allows you to configure switch port settings, including PoE, LLDP, speed, and VLAN.
Kay
Hello Kay,
We just created a few port profiles, with specific settings, like PVID, POE on or of, trunk or access. I saw i can change those settings like you mentioned above. (which does the same off course), but i would expect that you also can choose an port profile in the nebula app.
When i allready can change the PVID etc i don't think choosing an port profile would be an "advanced setting".
Agree with DPJ, the ability to view/change port profile through the app would be extremely helpful
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 310 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
