USG FLEX 200H -1.30 (ABWV.1) - the device does not make a copy of the configuration
- After updating the device to version 1.30 (ABWV.1), it does not copy the configuration with the weekly setting at a given time
Currently, the latest firmware for the USG FLEX 200H is V1.31. We recommend upgrading your device to this version to ensure optimal performance and security.
Regarding your concern about the configuration not being backed up as per your scheduled settings, could you clarify if you're referring to the configuration schedule backup? Additionally, where was this schedule set—on the Nebula Control Center or the local web configurator of the device?
We’ve tested this feature and found it to function properly in our environment. To better assist you, if you’re configuring this through Nebula Control Center, please enable Zyxel Support Access and provide your Nebula organization and site name. This will allow us to review your configuration and investigate further.
Looking forward to your update!
Kay
- After uploading 1.31, even Backups from before version 1.30 appeared and were not visible at all. In version 1.31, it is possible to delete many System Logs, but after using this option you need to refresh the window and this must be corrected
Do you mean that after upgrading your firewall to V1.31, the backup feature returned to normal, but you're now encountering an issue with the system log?
Could you please provide more details about the symptoms you observed? A video recording or screenshot would be very helpful for us to better understand the issue.
Thank you!
Kay
- After deleting many files, there is no change in the window (refresh) - the system deletes them but does not refresh the current window.
Could you please use the
tool to record a screen video and share it with us via private message?Kay
We have identified a web GUI-related issue that led to this situation. The fix is planned for an upcoming firmware release, version V1.32. Please stay tuned to the
for the latest updates.Kay
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
