USG FLEX 500 and Two SUBNET Interface
Smartmob
Smartmob Posts: 10 image  Freshman Member
I have a zyxel USG FLEX 500 firewall with lan1 interface (192.168.0.230 - DHCP managed by Active Directory) lan2 interface (192.168.33.230 - DHCP Disabled).
Any machine I set in the second subnet can only communicate with the firewall and has no internet.
What configuration did I forget?
    PeterUK Posts: 4,267 image  Guru Member
    edited January 14
    If your setting up a device with static IP on LAN2 for it to get to the internet you need to set the gateway and DNS both can be to the LAN2 interface gateway.
    If ping to 1.1.1.1 works but not DNS you need to have a firewall rule from LAN2 to zywall or if DNS works but timeout to 1.1.1.1 you need from LAN2 to WAN
  • Smartmob
    If I set the network card like this:
    I have no network or internet, I do not understand what it is that can block.
    I also tried setting a routing but no luck
    edited January 15
    Is "Enable IP/MAC Binding and DHCP Enforcement" checked for LAN2?
    edited January 15
    make routeing rule
    incoming LAN2
    next hop WAN
    check your on the right port and zone is set to LAN2
  • Smartmob
    I managed to configure everything but from lan2 I can ping lan1 but not vice versa
    there is no layer 2 isolation
  • Smartmob
    sovled
    edited January 23
    A static route? Should not be needed…
    is "Use IPv4 Policy Route to Overwrite Direct Route" checked?
  • Smartmob
    no is not selected
