DHCP and Secondary IP
It CAN be possible older models do it!
when you do a routing rule
incoming LAN
next hop WAN 2
SNAT outgoing-interface which will be the the DHCP IP
Or in my setup also
incoming WAN to Secondary IP 192.168.254.1
Source Address 192.168.252.0/23
next hop WAN 2
with Static route
192.168.252.0 255.255.254.0 gateway 192.168.254.2
Hi @PeterUK ,
To better assist you, please provide the following information:
- Which firewall model do you need this routing function for?
- What is your specific use case or business requirement for this routing function?
- You mentioned that some models already support this function. Could you:
- Specify which model(s)
- Share a screenshot of the existing configuration
Zyxel_Judy
Its the FLEX200 H and on a early version of the firmware it was possible see case #456511
The specific use case was that it worked and I used it and now have had to set it up another way which means a extra port was needed
It was done on a Zywall 110 which was replaced for more testing with FLEX200 H
Hi @PeterUK ,
Thank you for your interest. We are still evaluating this feature. We will announce it in our Firewall News & Release section if it becomes available in the future.
Zyxel_Judy
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
