Number of vlans in devices
I have a question, once I bought a swich smart 19xxx for a customer, I don't remember which one and I know that I was crazy, that I could only configure any 2 Vlans.
Could you tell me which devices have such limitations?
Hi @tczauderna,
If the issue happens again, please help to record the video so we can check this issue better. Additionally, you can try the tool "Jam" which can record your tab and save it on the cloud directly.
Zyxel Melen0
This switch have only 2 VLAN
I'm bringing up the topic
Source:
https://download.zyxel.com/XGS1930-52HP/datasheet/XGS1930-52HP_6.pdfSupport up to 4K VLAN ID** Cloud and standalone modes supported features.Probably you should take a deeper read into the user manual?
and don't forget to update firmware, .9 is currently available
Yes firmware i must update.
If the information was so available in the manual I wouldn't ask. And I don't remember where I found the information about it. The switch supports 4k vlan but you can't define static ones than 2.
For USG Flex it's similar but at least there is information but no one writes directly about it https://community.zyxel.com/en/discussion/17402/vln-limit-max-of-80 -
Hi @tczauderna,
XGS1930 series supports 4K dynamic VLAN and 1K static VLAN.
I'm not sure why you cannot create more than two VLANs. Our handbook shows it can set up three VLANs for example. Please reference our handbook chapter 2.1 to configure VLANs:
https://download.zyxel.com/XGS1930-28/handbook/XGS1930-28_2020.1.pdf
Zyxel Melen0 -
I will try to upgrade the firmware, maybe it will change something. I once found information about it somewhere, but I don't remember where. You know, now that I look at it, maybe it's a GUI bug and you can only configure 2 named VLANs and the rest from the so-called "finger" because I don't remember if I checked it
Hi @tczauderna,
Zyxel Melen0
- 603 USG FLEX H Series
- 480 News and Release
