How to remove user from Flex(200) firewall
Danee
Danee Posts: 9 image  Freshman Member
As the administrator account, I would like to remove one of the users from a Zyxel Flex 200 firewall.
The user's only group membership is the default "users" group.
But after marking the user from the list, all but the remove button is active.
Why is the "Remove" button inactive?
Is it a bug, was it ever meant to work, or something is holding back the user from deleting?
The user is not logged in, in any form.
I hope the answer is not the "restart the device!".
Best Answers
    edited January 2025 Answer ✓
    this for the FLEX H ?
    what firmware are you on?
  • Danee
    Running USG FLEX 200H V1.30(ABWV.0) 2024-10-16 16:28:21
    Thank you for pointing out, the new firmware V1.31(ABWV.0) fixes it. I will test it when I can restart the device.
    https://community.zyxel.com/en/discussion/27878/usg-flex-h-series-v1-31patch-0-firmware-release
    37. [eITS#241200162] Unable to delete a user in User Authentication > User/Group > User. The button "Remove" is greyed out.
