Problems with content filters in school
In a school we use a content filter on the Zyxel USG110 to protect the students. It works very well but there is still room for improvement. When I search for a porn site on Google, the site is displayed with a preview image... when I click on it, it is then blocked by the filter .. perfekt. How can I avoid pornographic images in my internet search?
Hi @IMPROMAT
To help block pornographic images during internet searches, you can enable the SafeSearch feature on your USG110. SafeSearch ensures that explicit content, including images, is filtered out during web searches.
For step-by-step guidance on enabling SafeSearch, you can refer to this discussion:
Kay
Is SafeSearch enabled?
No, it wasn't entered... I think that would be exactly what I'm looking for. I have now activated it according to the instructions... but since then I have had major DNS problems in the network and can only surf if you specify a 2nd DNS in the zyxel again.
I paid €400 for the license a month ago and now nothing works anymore... the content filter is also turned on and no longer works... I'm really desperate!!!! Do you have any idea how to get remote maintenance from a Zyxel professional?
old models don't support TLS 1.3 Kyber which breaks Content Filtering
Hi @IMPROMAT
Kay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
