Problems with content filters in school
IMPROMAT
IMPROMAT Posts: 5  Freshman Member
In a school we use a content filter on the Zyxel USG110 to protect the students. It works very well but there is still room for improvement. When I search for a porn site on Google, the site is displayed with a preview image... when I click on it, it is then blocked by the filter .. perfekt. How can I avoid pornographic images in my internet search?
    PeterUK Posts: 3,532  Guru Member
    Is SafeSearch enabled?
  • IMPROMAT
    No, it wasn't entered... I think that would be exactly what I'm looking for. I have now activated it according to the instructions... but since then I have had major DNS problems in the network and can only surf if you specify a 2nd DNS in the zyxel again.
  • IMPROMAT
    edited January 19
  • IMPROMAT
    I paid €400 for the license a month ago and now nothing works anymore... the content filter is also turned on and no longer works... I'm really desperate!!!! Do you have any idea how to get remote maintenance from a Zyxel professional?
    old models don't support TLS 1.3 Kyber which breaks Content Filtering
    What's New ZLD5.39 — Zyxel Community
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,276  Zyxel Employee
    Hi @IMPROMAT
    To help block pornographic images during internet searches, you can enable the SafeSearch feature on your USG110. SafeSearch ensures that explicit content, including images, is filtered out during web searches.
    For step-by-step guidance on enabling SafeSearch, you can refer to this discussion:
    Kay
