Stable and latest needs to be better
As it is you can't download a .bin of a release for FLEX H and both Stable and latest give you the same release firmware which given how bad V1.31 is at this time you might want to go back however Install firmware update on standby slot would solve it also but as it is the Stable and latest do nothing for FLEX H
Hi @PeterUK
Thank you for sharing your thoughts and feedback!
To roll back to a previous firmware version, the recommended approach is to switch the firmware partition. You can find detailed instructions here:
Regarding your other post, Install firmware update on standby slot, we have identified an issue where the cloud firmware update directly updates the running partition. This behaviour is not aligned with the intended design.
Our team is actively working to resolve this issue in the next firmware release. Once fixed, users will be able to utilize the partition-switching feature to revert to a previous firmware version seamlessly.
Additionally, we’ll be moving this idea post to the general discussion category to keep the Ideas section focused on feature requests.
Thank you again for bringing this up and helping us improve!
Kay
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
