Number of vlans in devices
tczauderna
tczauderna Posts: 30  Freshman Member
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
I have a question, once I bought a swich smart 19xxx for a customer, I don't remember which one and I know that I was crazy, that I could only configure any 2 Vlans.
Could you tell me which devices have such limitations?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,720  Zyxel Employee
    Hi @tczauderna,
    If the issue happens again, please help to record the video so we can check this issue better. Additionally, you can try the tool "Jam" which can record your tab and save it on the cloud directly.
    Zyxel Melen
  • tczauderna
    This switch have only 2 VLAN
  • tczauderna
    I'm bringing up the topic
  • mMontana
    mMontana Posts: 1,434  Guru Member
    Source:
    https://download.zyxel.com/XGS1930-52HP/datasheet/XGS1930-52HP_6.pdf
    Support up to 4K VLAN ID*
    * Cloud and standalone modes supported features.
    Probably you should take a deeper read into the user manual?
    https://download.zyxel.com/XGS1930-52HP/user_guide/XGS1930-52HP_V4.70_Ed2.pdf
    and don't forget to update firmware, .9 is currently available
  • tczauderna
    Yes firmware i must update.
    If the information was so available in the manual I wouldn't ask. And I don't remember where I found the information about it. The switch supports 4k vlan but you can't define static ones than 2.
    For USG Flex it's similar but at least there is information but no one writes directly about it https://community.zyxel.com/en/discussion/17402/vln-limit-max-of-8
  • Zyxel_Melen
    Hi @tczauderna,
    XGS1930 series supports 4K dynamic VLAN and 1K static VLAN.
    I'm not sure why you cannot create more than two VLANs. Our handbook shows it can set up three VLANs for example. Please reference our handbook chapter 2.1 to configure VLANs:
    https://download.zyxel.com/XGS1930-28/handbook/XGS1930-28_2020.1.pdf
    Zyxel Melen
  • tczauderna
    I will try to upgrade the firmware, maybe it will change something. I once found information about it somewhere, but I don't remember where. You know, now that I look at it, maybe it's a GUI bug and you can only configure 2 named VLANs and the rest from the so-called "finger" because I don't remember if I checked it
  • Zyxel_Melen
    Hi @tczauderna,
    Zyxel Melen
