Very horrible service, nightmare in fact
I have had a issue for weeks and have tried set up a teamviewer session several times and the support agent never shows up or reponses to my emails. This is extremely dissappointing.. how can I raise a complaint?
Hi @cucci_nj ,
We apologize for any difficulties you experienced with our support service.
If you are mentioning to the ticket #479519 about "tablet can access to local network without internet access", here is our recommendation:- Set Source to "HA_TABLET"
- Set Destination to "WAN"
- Set Action as "deny"
Please let us know if you need any further assistance.
Zyxel_Judy
0 - Set Source to "HA_TABLET"
There is no WAN selection option in the Destination drop down.
Hi @cucci_nj ,
You can add the WAN object under Configuration > Object > Address/Geo IP > Address, similar to how you created the HA_TABLET object. Remember to select the appropriate Address Type and Interface for your firewall.
Alternatively, you can directly select “WAN" it as shown in the screen below. Note: make sure to choose the correct "From" zone where your HA_TABLET is located.
Zyxel_Judy
Need to change Action to DENY and it works
Hi @cucci_nj ,
Thank you for your feedback. We're glad to hear that the issue has been resolved.
We understand that our local support team has successfully connected with you via TeamViewer and phone call. We have noted the missed appointment issue and will implement corrective measures to prevent similar problems in the future.
Update:
you can directly select “WAN" it as shown in the screen below. Note: make sure to choose the correct "From" zone where your HA_TABLET is located, and the Action as "deny".Zyxel_Judy
- 441 Beta Program
- 292 Service & License
