Console stops working if you access with wrong speed
PeterUK
USG FLEX 200H V1.31(ABWV.0)
So if you run PuTTY to the FLEX with wrong speed set you get a mess then when you run with the right speed 115200 it fails to work needing a reboot of the FLEX to fix.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Update
    This issue has been addressed and will be fixed in the next firmware release.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    I can reproduce this issue. Let me check with our engineer and I will update you once I have further information. Thanks!
    Zyxel Melen
  • Zyxel_Melen
    Update
    Zyxel Melen
