Guest Wi-Fi Time Expired pop-up box
I am trying to login to our new Zyxel USG60W and am getting the message box "Guest Wi-Fi Time Expired". This message box continues to reappear after clicking the OK button. I cannot get past this to make the modifications necessary. I think this only started after switching to easy mode.
Hi @RT_CSIWelcome to Zyxel Community.
We have addressed this situation, and will fix it in next release.You can reboot your device, and the symptom will disappeared.0 -
Has this been resolved and released yet? Does turning the guest network off also "resolve" the issue? Seems like it's taking a long time and my clients USG40W has latest firmware.0
I am on USG60 with firmware 4.35-AAKY.2 (the latest available). No issues in advanced mode. Appears only in Easy mode.
Easy mode is no longer usable; fortunately after the problem first started, I was able to (briefly) switch to expert mode as the default login .... and I am about to find out if the guidance above works for me (ref: "You can reboot your device, and the symptom will disappeared.")
I rebooted the device and haven't been able to re-create the issue.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
