In WRR Trunk Load Balancing, add "Bind all sessions from one IP" option on H series Zywall
AndreaRP
AndreaRP Posts: 1 image  Freshman Member
WRR distributes sessions among available WAN interfaces/lines.
However, this may have an adverse effect if multiple sessions from the SAME client are spread among WAN interfaces, effectively showing different IP addresses from the different interfaces. Some sites/apps/services require more than one session to be open, and the different origin of the connections trips some security alerts.
Some other manufacturers already have a "bind sessions from IP to interface": if checked, all sessions coming from one IP are bound to a single interface.
This reduces the effectiveness of the load distribution if there are just a few clients and only one of them opens a lot of sessions/transfers, but has a negligible impact on the distribution when there are more clients. At the same time, it solves the operatinal problems deriving from sessions "coming" from different WAN IPs
0 votes
Active · Last Updated
    PeterUK Posts: 4,719 image  Guru Member
    Wouldn't a routing rule works with wildcard FQDN like *.live.com?
    So a top rule would look like.
    Incoming LAN1
    Destination address *.live.com
    next hop WAN1
    So that when the client does DNS the routing rule uses a give WAN for IP's of *.live.com
    or you can have a client given source IP to use I give WAN.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,091 image  Zyxel Employee
    Hi @AndreaRP,
    Thanks for sharing this idea. I have let our product team know this request and we will monitor this post, the comments and the votes, to evaluate this idea.
    Zyxel Melen
