I have a question about an IPSEC with VTI.
lvdk
lvdk Posts: 5  Freshman Member
edited January 28 in Security
I have two routers (USG FLEX 700H AND USG FLEX 500) with dual wan
I have made an IPSEC from ROUTER-1 WAN 1 to ROUTER-2 WAN 1
I have made an IPSEC from ROUTER-1 WAN 2 to ROUTER-2 WAN 2
Remote LAN Router 1: 192.168.100.0/24
Remote LAN Router 2: 192.168.1.0/24
Router 1:
VTI1(via IPSEC via WAN1): 10.10.100.1
VTI2(via IPSEC via WAN2): 10.10.101.2
Router 2:
VTI1(via IPSEC via WAN1): 10.10.1.1
VTI2(via IPSEC via WAN2): 10.10.1.2
The tunnels are online. The VTI is also working. I can do a PING from client to the other subnet.
Now the question: If I turn on Connectivity Check to remote VTI address or to remote subnet address, the VTI goes dead.
The intention is that if the first IPSEC goes offline, there is an automatic failover to the 2nd IPSEC.
How can I get that working?
  • valerio_vanni
    valerio_vanni Posts: 157  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Router 1:
    Router 2:
    Your VTIs are Router1-WAN1 <> Router2-WAN1 and Router1-WAN2 <> Router2-WAN2?
    If you set
    Router 1:
    VTI2(via IPSEC via WAN2): 10.10.101.1
    Router 2:
    VTI1(via IPSEC via WAN1): 10.10.100.2
    and point connectivity check on the other side, does it fails?
    PeterUK Posts: 4,038  Guru Member
    So the ping check is on FLEX 500 due to 700H not having this yet
    So for the ping to work the IP you should ping the IP in VPN settings at the bottom VTI Setting Local IP with a firewall rule From zone of your VTI to Zywall
  • lvdk
    I don't think that is possible in the VPN settings. When using a VTI tunnel, the 'Connectivity Check' option is not visible. It is only available for the 'Site-to-Site' option, but I am using the 'VPN Tunnel Interface' option.
    If I activate the Connectivity Check on the VTI, the VTI goes down. When I check the log on the remote router, I don’t see any message about ping blocking.
  • valerio_vanni
    Router 1:
    Router 2:
    If you set
    Router 1:
    Router 2:
  • lvdk
    Yes, this works. Great. Thanks for the help!
