Can you join an ATP to Nebula and not lose it's configuration?
I have an existing ATP 800 that is currently in Monitor Only mode in Nebula. I would like to switch it to Cloud mode, but I get a warning that it will back up the config and then erase everything other than the WAN configuration.
If that is the case, can I save the startup-config and then apply it once the ATP is in Nebula?
HI @bwoolley ,
The ATP 800's on-premise startup configuration cannot be applied to ATP 800 in Nebula.
Instead, you will need to first preconfigure the ATP 800 in Nebula and then switch the ATP 800 to Nebula cloud mode.
Zyxel_Judy
HI @bwoolley ,
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
